Sorry removed
Three Minute Fire
Tags: None
Re: Three Minute Fire
very nice you make it look easy. can not wait to be not able to lite my first fire and also not be able to remove my pizza from peel .. this is such a good forum i think i could any thing somebody always has the answer -
When your oven is new it is still relatively moist and a bitch to fire. The fire is hard to light, smokey and difficult to build up. The more firings you do the better it works until it is perfectly dry. The same applies after prolonged wet weather and no use.Kindled with zeal and fired with passion.Comment
Hello Doug
When the firing is over, do you ever insert the next portion of wood to be sure it is cured for the next firing?
Your nice, big opening makes things a bit easier while cooking, cleaning, etc.
Lee B.
DFW area, Texas, USA
I try to learn from my mistakes, and from yours when you give me a heads up.Comment
i am just after doing 6 pizza in my home oven ... and the last one was a flop . the hole center stuck to my pizza tray .on me pizza stone . can you imagine how many pizza pie.s will be going to the dog when the heat is twice as hotter,,ha,,ha,, has anyone every tried putting 3 or 4 spoons or power skimmed milk in there pizza doughComment
Finished the oven landing yesterday!! WooHoo!Originally posted by Karangi DudeHey Lee,
How's things with your build?
....snip....
Cheers Doug
Thanks for asking Doug.Last edited by Lburou; 05-12-2011, 06:23 AM.Lee B.
I'm not a fan of using newspaper - I use a tiny piece of odour free firelighter (Jiffy brand in Oz) and the fire is roaring in next to no time. I have to place it in the centre from the start or else the flames go up the flue. Wood needs to be super dry for best results. The local gum trees seem to have "highter fuel" by way of gum in the bark which is an accelerant and aids ignition./ RosscoComment
hi laur... about the powerd milk it is some thing i found on the net it is ment to make it lighter and fluffier it also gives very nice texture to it and is very nice as a deep pan pizza . wit olive oil in it .Comment
I dont like the fine ash that it produces and the reason I never throw paper serviettes or anything else into my oven. The Jiffy firelighters are perfect and 1 small block is perfect to get the fire roaring in no time. Personal preference really though others may see it differently./ RosscoComment
I use a weed burner to fire up my oven. Since it is a propane powered torch, I can control fire size and length of burn. No problems with the fly ash for me. Down side is the boss hates it when I have to get a new tank of propane. Next stop is a natural gas hookup. In the immortal words of Bevis and Butthead - "Fire, Fire Fire"Comment
discourage guests from using the oven as an incinerator to burn stuff.
