Like many others, I have developed cracks during the cure process. I noticed the cracks after the 500F fire. The oven is covered with about a half inch of homebrew. The question is: Do I continue the fires up to the final cure to see how bad it's going to get, or do something about it now? I guess another question would be: Should I do anytheing about it at all?
Leigh
Leigh
. If you fix them, the oven will either crack again in the same place or crack somewhere else
