Two Meals in One Day?
  • poweredbypizzas
    • 15
    I will be making pizza for a set of friends at lunch time, and then again for family and friends for dinner. I don't want to keep the fire stoked for the 5 hours between. Should I just let it go, without the door on, or should I put the door on, which will extinguish the flames, but retain the heat?
  • Les
    • Sep 2005
    • 2945
    Re: Two Meals in One Day?
    I've never done it but I would put some fuel on the existing coals and "lean" the door to block most of the air. It should keep things going until you need to fire it up. Pizza twice a day - you are a lucky guy!
    • mrchipster
      • Apr 2010
      • 1502
      Put the door on and just wait until you are about 30 minutes to cooking the second batch and fire it up again, it will not take long and you will have saved a bunch of heat.
      Chip
      Chip
      • GianniFocaccia
        • Jun 2009
        • 1645
        According to several previous posts describing the "WHOOSH" that occurs when removing said door from a resting fire, cover your eyebrows!
        • mrchipster
          • Apr 2010
          • 1502
          Good advice John, after 30 minutes with a closed door there is little chance the the fire will flair up in a woosh. this generaly happens when the fire is still quite active.
          but just to be safe stand to the side for a minute or so to guarantee any flair up has been averted
          Chip
          Chip
          • Bacterium
            • Apr 2007
            • 560
            It's funny how movies create an awareness of something .....potentially allowing you to avoid an experience.... or maybe the challenge to pursue it
            Damon
            Build #1
            Build #2 (Current)
