What correct refractory cement should I use to repair the failure of the Refractory cement in the joint of my inner arch. The arch is in two solid pieces and is not moving at the base on either side. I only need a little, mabey a qt total to repair a few other novice bricklayer mistakes. The pictures should explain it better.
Derk
Derk
