Steady good heat without the large flames. How?
  • V-wiz
    • Oct 2012
    • 737
    Ive been curing the oven for a few days now. Started out with a propane weed burner, did that about twice, got it up to 175-200. After that ive been using charcoal and heat beads/briquets. Last night i got the oven up to 350-375 using charcoal and some small chunks of wood. So how does one create a steady, even hot fire while not having flames, or at least large flames? What do you do? lay out small pieces of split wood all over the floor and light it up so the heat is evenly distributed? or do you create a fire in the middle then spread it out?
    Here is a picture from last night. The charcoal is not cutting it anymore, i need more heat.
  • okn
    • May 2011
    • 133
    Re: Steady good heat without the large flames. How?
    Nice picture. I don’t have a great answer for you. As I was doing my curing fires I kept thinking about where to measure the temperature. I mean it’s all over the place when you have a small fire. The dome could be 500 under the fire, 300 where the dome meets the side wall, the side wall at 250 and the floor by the side wall at 175 and floor by the fire at 300. I just ended up building progressively larger fires, and when they burned down spread the coals and closed the door.
    By the way, I forgot my oven thermometer (like the one in the picture) inside the oven and built a fire right on top of it. After racking it out of glowing coals, I had more or less burnt all the writing off it.
    • V-wiz
      • Oct 2012
      • 737
      thanks man, that sucks that you burnt up the Thermo, well it so cheap you can get another one.
      • stonecutter
        • Jun 2007
        • 2003
        Just burn smaller fires in the center until you get enough coals to spread to the walls. No biggie..just be patient.
        Old World Stone & Garden
        John Ruskin
        • Tscarborough
          • Oct 2009
          • 3341
          Cactus burner.
          • V-wiz
            • Oct 2012
            • 737
            By doing this that would mean having hot spots at the center/top of the dome and having the bottom walls be a lot cooler, and doesn't this cause cracks? the large temp variation? Is this the correct understanding?
            • V-wiz
              • Oct 2012
              • 737
              Originally posted by Tscarborough
              Cactus burner.
              Whats that?
              • stonecutter
                • Jun 2007
                • 2003
                It hasn't caused a problem in the past...but the key is keeping the fire small and continually move coals to the perimeter. Oh, and as we all know, cracks happen eventually...causing damage from rapid expansion is what you are trying to avoid.
                John Ruskin
                • Tscarborough
                  • Oct 2009
                  • 3341
                  • V-wiz
                    • Oct 2012
                    • 737
                    Oh ya ive got one, i mentioned i used one, i didnt like that method. Rather use wood as its more even
                    • V-wiz
                      • Oct 2012
                      • 737
                      Got it, thanks
                        • 2848
                        Gudday
                        To quote Laurentus, Newbie forum, "Heat drops fast"....
                        Quote "Then, cook something while it cures" Unquote
                        Well why not ....it doesn't have to be a 90 sec pizza does it.
                        Regards Dave
                        • Tscarborough
                          • Oct 2009
                          • 3341
                          Is yours 500,000 BTUs?
                          • V-wiz
                            • Oct 2012
                            • 737
                            ^ probably not. Show off, trying to flash your guns???
                            • V-wiz
                              • Oct 2012
                              • 737
                              Im a bit hesitant as you can imagine, last night the first few cracks appeared, hair line cracks around the top perimeter and down a few rows, it closed up mostly when it cooled down in the morning. So i want to be cautious and take it easy, and do it right. Im hoping to get the heat up to 400-425F tonight. From what i understand, build a small fire in the center, keep on adding fuel and spread it around, is this correct? Thank you.
