Ive been curing the oven for a few days now. Started out with a propane weed burner, did that about twice, got it up to 175-200. After that ive been using charcoal and heat beads/briquets. Last night i got the oven up to 350-375 using charcoal and some small chunks of wood. So how does one create a steady, even hot fire while not having flames, or at least large flames? What do you do? lay out small pieces of split wood all over the floor and light it up so the heat is evenly distributed? or do you create a fire in the middle then spread it out?
Here is a picture from last night. The charcoal is not cutting it anymore, i need more heat.
