Wet oven
  • PrimopizzaKC
    • Aug 2013
    • 3
    Wet oven
    I just finished curing my oven and put a layer of blanket insulation over it. It reached perfect temps. I placed a tarp over it and thought it was secured, but a thunderstorm in my area thought differently. I know my blanket is probably trashed (Luckily I have more), but do I have to cure my oven again? I think my ceramic board on the bottom should be all right shouldn't it? I remember reading that James had intentionally left FB Board out in the rain and it has held up just fine. Any information would be appreciated. Thank you.
  • thickstrings
    • Aug 2012
    • 138
    Re: Wet oven
    My board was wet from a hole in the tarp and continued firing eventually dried it out with no damage...I would'nt doubt that the blanket would be the same...
    • tusr18a
      • Mar 2010
      • 95
      Re: Wet oven
      The ceramic fire blanket and board will dry out. No need to replace. Due to the storm, if the fire bricks were saturated with water, I would recommend going through the curing process again. After all the hard work, you want to do everything possible to avoid cracks in the dome. If you are in a rush, you can forego further curing. Cracks tend to naturally appear anyways. Not a big deal.
      Depending on how wet the insulation is, you may have trouble getting the oven to temp until the ceramic fibre material and bricks dry out some.
      • PrimopizzaKC
        • Aug 2013
        • 3
        Re: Wet oven
        Thanks for the reply. I cured it all over again and I'm good to go!
