Hi everyone, I just finished my first oven and I'm having trouble keeping the fire lit. I built it to the instructions, but I think I'm having an airflow issue. Any ideas?
Re: Fire won't stay lit
Lifeofpie,
Here are a couple of possible answers: You say just finished the WFO, so is the oven dry? If the oven is still wet/water in bricks/not dried out it won't act properly. Another possibility is the wood: how dry is the wood you are using? The problem could be a combination of the two.
You might try a draft door to improve draw. I use such a door and it causes my WFO to draw like there was a fan blowing air into the WFO. Shortens time from match to first pizza significantly as well as lessening any smoke that may want to escape out the front. Lots of postings about draft doors, check the archives.
Hope these ideas help. I'm sure others will chime in with other possibilities.
Wiley
can you post pictures? Are you starting your fire near the front and only pushing it back once you have a strong fire and draw going? It is very difficult to start the fire in the center of the oven. In my oven, the fire needs to be strong and the chimney hot before I can push everything into the middle and stoke it up!
Likely a wet oven as mentioned by the others. If smoke is choking out the fire, then the chimney opening is probably undersized. A small fire built close to the oven opening or a twist of newspaper to heat the flue is going to help get your draw going.Old World Stone & Garden
John Ruskin
I think I was doing a bunch of things wrong. I didn't have enough kindling, too big of a log to start with plus it had about 9.5% moisture according to the meter. Pretty dry, but could be drier. I'll look up a draft door and try everyone's suggestions in the meantime. Also, I'll get a few pics up. Thanks for the help.
Here's a pic of it basically done. I also rigged up an automatic door of sorts that uses an RTD in the middle of the floor to sense the temp and then will open or close to maintain the temp. I couldn't find any info on the forums and obviously I'm not sure if it works yet. Has anyone tried this? If so, results?
My 2 cents is your wood has to be wet. If your useing kindling and get that started in the front of the oven with bigger chunks and get those going you should never have a problem. Once its going well under your chimney push it into the center of the oven it will roar as long as your woods not wet. Seasoned wood is easy to identify by looking for cracks/checking in the grain at the end of the logs. If no cracks it's not dry. It takes at least 6 months stored indoors dry to season wood in NW Pennsylvania.Chris
Link to my photo album:
Use a torch to start it up and put a draft door, my draft door quickly and I mean instantly lights the wood into flames.Matthew 19:26. With God all things are possible.
Really?Originally posted by lifeofpie View PostI also rigged up an automatic door of sorts that uses an RTD in the middle of the floor to sense the temp and then will open or close to maintain the temp.
Did you wonder why you couldnt find anything related on the internet?
Almost certainly believe your problem is a new and wet oven. They are always a bitch to keep the early fires alight. Beware that as soon as the oven interior dries a little and the fire stays alight ok, the rest of it is still wet and in danger of damage if you boost the fire up too soon. Take it slow and follow the guide on the curing thread.Originally posted by lifeofpie View PostHi everyone, I just finished my first oven and I'm having trouble keeping the fire lit. I built it to the instructions, but I think I'm having an airflow issue. Any ideas?Kindled with zeal and fired with passion.
Hi
Use Doug's method of using heat beads to begin drying process.
