Re: Kiln dried Vs Seasoned?
By weight? Man, talk about volumetric variables. Depending on how green the wood is, weight is all over the place. No wonder you guys want dried up deadfall by the ton, that would be a lot of timber.
It really is different in your neck of the woods.
My mate dabbled in firewood supply as an income supplement.
Over here people grizzle if the timber hasn't come from a fully dead tree. They want well and truly dead redgum, or mallee roots. Nothing else. Red gum that died several years ago has no bark, is grey on the outside and red on the inside, and that's just the way they like it.
The branches are the same whether they are 2 inches thick or ten. Pound for pound same calorific value. But redgum is a very dense slow burning wood, which is another reason I like the thin stuff - for a given weight there is much more surface area burning, meaning quicker release of heat to the bricks.
Over here of course, wood sells by weight, not volume.
So we don't have discussions about whether a cord of wood is well packed, etc.
I imagine if timber is being sold by volume, split logs would pack best and thus deliver the most BTU's per cord.
Instead we have arguments about whether the wood dealer's ton was really a ton.
Where I come from there is also a lot of wood. And it is very true here too, that most don't bother with the brush. I follow behind the firewood cutters who sell their split hardwood pickup loads for about 125 to 150 bucks. It seems that they regularly think of 5" to 6" and under as brush. I guess it depends on where and how it is laying on the ground once it is felled. I wouldn't want to cut and haul firewood every day but, I get a kick out of getting something for next to nothing. I'm not sure about the BTU's of split vrs. limbs, but I do know that limbs will clear a dome
Not what I'm saying...and not what I mean.
This is a matter of prospective. There was so much wood where I came from, you don't bother with the brush, and that is exactly what the small stuff is. The btu yield is not as high as split logs, the time it takes to break down small branches is comparable to processing large wood...with the right equipment. I know that this thread is about wood for recreational ovens, so I guess my point is useless.
I am sometimes guilty of posting things that come from a professionals prospective, this type of work was part of what I did for years during the winter. So in this case , the value iis not on the small branches. And I do get the value of using deadfall and such. But sometimes " killing" a tree is actually better for the health of the wood lot...and customers don't want dead wood.Leave a comment:
It takes way too much of my time fiddling around with splitting the big stuff.
It's different over here, obviously. Eucalypts have an endearing habit of dropping branches. Which is fine if you aren't parked under them at the time.
With some gums, that can be a live branch that will take for ever to season.
However, the really long lived eucalypts have branches die on the tree. Then it snaps off clean. By the time it hits the ground there is nothing but extremely dry timber. No bark. And then the firewood scavengers come along and take the bigger bits and leave the thinnings behind.
Then I come along and say thanks very much for leaving me the smaller wood.
Which is already the size I want, is light and easy on my mangled back, and cuts easy in any saw. Some varieties actually shatter into the right lengths when they land on the ground - no BS.
Anyway, the best bit about eucalypts - you never have to actually kill a tree to get a ute load of very well seasoned wood.Leave a comment:
I guess my time is not quite as valuable. So I'll just keep cutting "brush.....under 3" to 4"
................ But, I do agree with using the right tool for the right job.......It is a h
ll of a lot safer
It takes way too much of my time to fiddle around with brush. If I needed it because of a limited supply, that would be a different storyLeave a comment:
You can say that for any type of tool that we every use. They might be designed for one thing, but there are a lot of other uses than what is printed on the sales literature.Thats a fact...but some are more proficient at it than others.
Personally, if I cut anything under 8", it was right off the crown of the tree I just dropped....everything is cut to length with a chainsaw. Anything under 3"-4" is for the chipper or burn pile. Granted I had all the wood I wanted so I could pick and choose. But you won't see me using a miter saw to cut rough timber..ever.
Stonecutter- sorry to hear you throw all the small stuff away, you still have to go through the process of chipping it or burning it and you get no benefit out of it by disposing of in that manner. Long time ago when a person could talk freely and not have to worry about political correctness, you'd day. Injun make small fire and stand close, White man make big fire and stand far away! Make big smoke and waste too much wood! Not even peace pipe or happy smoke! But both stay warm!
All that good small stuff makes really good fire--just a little effort handling it. Just like utilizing a resource that in other places of the world is so highly prized!Leave a comment:
Personally, if I cut anything under 8", it was right off the crown of the tree I just dropped....everything is cut to length with a chainsaw. Anything under 3"-4" is for the chipper or burn pile. Granted I had all the wood I wanted so I could pick and choose. But you won't see me using a miter saw to cut rough timber..ever.Leave a comment:
I've tried them all.
Hydraulic log splitters, chainsaws petrol and electric, tractor mounted bench saws made for the very job at hand, handheld circular saws, drop saws, mitre saws, axes sharp and blunt, jigsaws, reciprocating saws, etc.
They all have one thing in common.
Anything that can go through wood will have absolutely no problem going through human flesh and bone.Leave a comment:
The safest way is to use a solid bench a lever arm and 'u' bolt to cramp the timber and two people one operating the cramp and one cutting you will be surprised at the speed. Much faster then a the trip to hospitalLeave a comment:
G'day
I agree but its slower on Aussie hardwood. But with the timber clamped into a set of jaws you have both hands in view.
Regards daveLeave a comment:
You guys are all going to be nicknamed lefty if you get this up.
The only tool that is any good for cutting rough timber is a reciprocating saw, corded or battery...demo blades work best.Leave a comment:
The farmers around here don't bale with twine, all their baling is with a plastic wrap either white or black. That is true for straw and hay. The dairy farmers import most of their hay from Canada or the United States. Those bales are sometimes round, but mostly square. The square ones are packed tightly into an ocean container and the dairy people have a special attachment to a forklift to pull the feed out.
I'll have to take a picture some day of the old Ryobi chop miter saw. This is used exclusively for wood cutting. The photograph you attached is of something I would only use for cutting steel products. Don't even remember what they were called in America--had one there but left it there when I moved.
Only reason I used wire was to make it easier for stacking. If burning the branches, always would only use a little at a time. If I could find the rope your talking about it would work slick. We used to call that "bukka-lunga" but that is an all inclusive name for small rope. Old times before tape--in butcher shops the butcher would wrap the meat up in white paper and tie it closed with a white cord. We would save the cord and tie the ends together to make a long cord. There is a tourist attraction in Minnesota of a huge ball--taller than a man that was saved "bukka-lunga"--Maybe Mrchipster heard of it!Leave a comment:
G'day
Thanks (especially Mick) all for letting my have me little whine. I usually spend my time hiding it and getting on with things. Felt good to say it
