Check out my cracks
  • Dave T
    • May 2015
    • 58
    Check out my cracks
    I have a new Casa 2G100, installed by a masonry contractor. I waited 2-3 weeks after it was installed to begin curing, and carefully followed the curing instructions on this site over a week. Just made my first pizzas over the weekend. I do have some cracking, but I'm not sure if I should care. The masonry between the joints of the oven pieces looks like it's separated a little, and there are a couple small cracks forming that I'm concerned could grow into something serious. Could someone please look at these pictures and let me know if I should be concerned?
    These photos were taken of the dome with a hot fire in the oven (dome had turned "white"):
    little hairline cracks like that are normal and will probably never get any bigger.
    • Dave T
      • May 2015
      • 58
      Thanks. What about the joints in the dome? Is that normal?
        It looks like the mortar has oozed through the joints a bit and not pointed from the inside. You wouldn't want bits falling on your food, so scratch away at them to dislodge any bits that might fall off later.
        • fornax hominus
          • May 2009
          • 157
          This is where you need somebody skinny and not claustrophobic to slide in the arch and start chipping , I had to put one arm up and slide in on a platform ..i took the phone in with me in case I got stuck !
          I didn't, and only a few minor panic attacks .. no more mortar in the pizzas since
