Choosing and finding wood
This is a sticky topic.
Re: Choosing and finding wood
Has anyone has tried Princes Tree (paulownia)?
It's a fast growing tree that can be used as a biomass but i don't know if i could burn it as a wood log.Comment
From the internet ... characteristics "Paulownia is a very good
insulator. Paulownia log homes are said to have twice the R factor as
pine or oak logs. This temperature resistance serves to give the wood a
high fire resistance. Ignition temperature is approximately 400 deg. C.
which is almost twice many conventional American hard and soft woods."
There are other mentions that basicly say that while it will burn, it doesn't have a high BTU....Hard to start, but OK to use..." Life is art, live a masterpiece"Comment
Have you seen a btu rating for paulownia?From the internet ... characteristics "Paulownia is a very good
There are other mentions that basicly say that while it will burn, it doesn't have a high BTU....Hard to start, but OK to use...Comment
hmmm. Everything I read says it is an invasive species, stinks when burnt, and has low BTU content. Sounds like a pass!Comment
Here ya go Dimitri, [Homestead] Paulownia elongata and another Can You Burn Paulownia? | eHow I have no personal experience with Paulownia.Last edited by thickstrings; 10-10-2013, 03:44 PM." Life is art, live a masterpiece"Comment
Thank you!Here ya go Dimitri, [Homestead] Paulownia elongata and another Can You Burn Paulownia? | eHow I have no personal experience with Paulownia.
I can't though spot the low BTU and smell anywhere on those articals.
Seems the same readings is actually all over the net, I can't seem to find a personal opinion of a person that has actually burned paulownia.Last edited by dimitrisbizakis; 10-11-2013, 01:23 AM.Comment
Dimitri, After looking on the net a few places, it basicly says, if its real dry, it burns like cedar...not sure of fumes, as I find no mention...but wet wood will smolder and stink. All you can do is try it. ..at least to just come up to heat...switch to the better stuff later." Life is art, live a masterpiece"Comment
I am planning off planting thouse trees for firewood for heating and wood oven.Dimitri, After looking on the net a few places, it basicly says, if its real dry, it burns like cedar...not sure of fumes, as I find no mention...but wet wood will smolder and stink. All you can do is try it. ..at least to just come up to heat...switch to the better stuff later.Comment
