Re: Tall fire, yes. Wide fire too.
Thanks for the suggestions.
I had so much trouble with scorched loaves, I opted to let the oven cool down quite a bit. My 500 was a door temp; the dome and floor were hotter. I will follow your suggestion and go a little hotter next time, maybe 540, now that I have things a little more under control. I'm just pleased not to have 1/8" + of charcoal on the bottom and a little less on the top.
I'm also a little skeptical about how accurate door thermometers are. I've put three oven thermometers in my kitchen oven and gotten three pretty different readings. My 500 may be your 540.
Good point about swabbing later. I can't think of any benefit from swabbing earlier, and using the moisture is a good idea. I did spray quite a bit before loading. I'll swab before loading next time.
Thanks again.
Karl
Thanks again.
Karl
