Today, I will start my holiday cooking for a crowd. I have a number of pieces of meat to roast, but it was pointed out by more experienced members of the board that some of the things that I did not like about my first roasting attempt could have been due to a less than fully heat saturated oven. So, starting about 9 am this morning I have started a fire in the oven. I am taking somewhat of a risk by not only not using oven/kiln dried wood,the way I would if I was cooking pizza, but rather, I am using 2 5-6 inch wide logs with bark on them, on a small log holder, with coals under the holder and a couple of oven dried logs about the size of your wrist (all oak). My plan is to run that fire for a couple of hours and start the roasting about noon. Those bigger logs should burn for hours. Next time I split wood, I hope to not be lazy and leave anything bigger than my wrist. 5 to 6 inch logs seem too big. I have just cut up stew beef, which will be roasted and then combined with the usual all for the next few days as stew is always better the next day. Later today I will also do a 15 lb brisket. A little apprehensive over that one.
But I do think the fully saturated heated oven will be the key to success.
