Door Construction
  • C5dad
    • Oct 2005
    • 422
    #16
    Re: Door Construction
    Aww man, I like the flavor of Zinc that fumes from the galvanized metal. Just bummed they took the arsenic out - imparts a sweeter flavor
    Seriously though, this is great advise from all so far. It is way cool to find out what everyone is doing for us greenhorns. I know others out there are probably thinking the same about how others are making their doors.
    If others can post pics of their doors, that would be great for all to see and get ideas!
    CW
    p.s. I don't procrastinate, Its just better to put things off til tomorrow that I can do later today - gotta leave my options open.
    Follow my build Chris' WFO
    • Lburou
      • Dec 2010
      • 1165
      #17
      I'm so flexible, I don't need to procrastinate
      Someday, I'll be making one of these doors....Is there any contraindication for the use of aluminum rivets, I have some of those in my tool box already
      The black hi-temp paint looks good to me, like fxpose did.
      Lee B.
      DFW area, Texas, USA
      • Les
        • Sep 2005
        • 2945
        #18
        I don't have a picture in the office, but here is a link to my page.
        http://www.fornobravo.com/forum/8/le...d-4207-10.html
        Many have posted pic's in the past, but it's been pretty scattered. It would be nice if all were in one location since everyone needs a door.
        Les...
        • bbell
          • Oct 2008
          • 195
          #19
          Les, that's a great idea! Would be helpful to have door ideas in one spot.
          My first door was the only a piece of plywood wrapped in Aluminum tape with a shelf standard as a handle. If i use it when the oven is too hot I can hear the wood smoldering and popping.
          Then made an insulated door that works well when I want to keep the oven temp up as long as possible.
          Now thinking of a draft door to help speed up the lighting of the fire. I'll scout around and see what others have done.
          Bill
          Oven Build: https://goo.gl/photos/rN6FhFSS2jzwfQuB7
          Oven cooking: https://photos.app.goo.gl/1vmPg7XXSbMwhdnD6
            Speeding up the firing by using a draft door or forced air induction (hair dryer) has a drawback in that it creates a temp rise that is too fast for refractory materials to handle. It is the difference in temp and its consequential difference in expansion of the materials that is the problem. For safe practice the standard temp rise should be no greater than 100 C/Hr This is not practical for us but just bear in mind that sudden temp fluctuations damage the materials, it doesn't matter how good or how highly rated your refractory materials are if you subject them to major stress. In short I think it's better to give your oven more time rather than trying to achieve the big fire too fast. This technique also provides more drinking time.
            • azatty
              • Sep 2010
              • 239
              #21
              Chris, if you need another resource, shoot me a PM and I'll send you the contact information for my friend in Mesa who's fabricating a door for my oven. He's familiar with the brick oven application, and he does great work.
              • C5dad
                • Oct 2005
                • 422
                #22
                I may just do that - I will check with the guys in my shop as to when we can do the cutting and what not - got a HUGE shop at the mine/smelter with all the tools one would need. Unfortunately, work is the same - more than what the guys need.
                • SableSprings
                  Moderator
                  • May 2009
                  • 1310
                  #23
                  When I got my oven completed I had a stainless steel door constructed with a hollow center. I filled the center with leftover perlite for insulation. The door worked great for heat management, but was far too heavy to lift with one hand while loading bread into the oven. I had a second, light working door made out of sheet steel. The handle was made out of an old coiled grip and welded to some round bar stock. The round stock is forked at the base to give the door stability. I can now lift the door with one hand while holding a loaded peel in the other. I can use the light door for pizza or bread bakes without having to use a glove. As you can see in the pictures, the light door steel is slightly "creased" to allow for heat expansion and then I simply painted it with high temp black spray paint.
                  I'm pretty happy with my two door system and it gives me a lot of options.
                  Mike
                  Roseburg, Oregon
                  • bbell
                    • Oct 2008
                    • 195
                    #24
                    I also found this prior thread with a pretty fancy glass door. Pretty good!
                    http://www.fornobravo.com/forum/f9/g...view-5169.html
                    Bill
                    Bill
