Water in my Primavera
  • Kid800
    • Jan 2011
    • 7
    We've had some heavy rain in the NE and even though I had the cap on the chimney and the door closed tight, the rain was coming sideways and a substantial amount of it is in the oven.
    I started a curing fire and the water began dripping from the bottom of the base. I got high heat at the top but nothing over 400 on the sides and maybe 500 on the floor.
    Is the oven a loss or can continued fires dry it out completely?
    I just sent for the cover from FB; hope it's not too late.
    Anything will be appreciated.
    Thanks,
    Kid
  • terrihoward
    • Jun 2010
    • 17
    Re: Water in my Primavera
    Keep the fires going, it will dry out again!
    • Tman1
      • Aug 2010
      • 346
      If there is water in the insulation under the floor, try and lift up the tiles to expose them to more air. Those will take a long time to dry out without adding air exposure. Wouldn't be bad to keep fires going everyday to help dry it out. You don't have to use the best wood.. it can be anything. I use scrap 1x4 and 2x4's because they're cheap and it burns.
      My oven (for now):
      http://www.fornobravo.com/forum/f43/...ven-14269.html
      • Les
        • Sep 2005
        • 2945
        Ditto - heat will prevail.
        • Kid800
          • Jan 2011
          • 7
          Thanks, I suspected as much but I needed reassurance!
          • HeidiL2011
            Hi Kid800,
            As everyone else already said you need to re-cure the oven and if the insulation under the floor got wet, please lift the floor tiles to allow it to dry out.
            If you have any other questions feel free to contact me at 1-800-407-5119 ext 14
            Thanks,
            Heidi
            Forno Bravo
            • Kid800
              • Jan 2011
              • 7
              Thanks, I can't wait till the cover arrives!
              • mrmojo1
                • Apr 2012
                • 5
                hi is the cover still available? I don't see it on the home site? thank you!
                • Neil2
                  • Oct 2006
                  • 1374
                  "If there is water in the insulation under the floor, try and lift up the tiles to expose them to more air. "
                  This can be a problem. Especially if your oven design is such that the insulation layer under your floor is confined in a "bathtub".
                  Repeated firings can eventually dry it out, but you may also want to consider drilling holes into this area (either from the side or bottom) to provide positive drainage to speed up the process.
