great resource--first time poster. I have a brick oven with a house I recently purchased--seems to be in working order. Been trying to do some slow burns over a week to get any moisture out since I susepct the oven hasnt been used in well over a year. I have a basic question (which might be silly):
I understand it can take 90-180 mins to fire up the oven and the importance of heat management. Do you keep the oven door mostly closed during this time? Or do you try and go with a full fire with the door open? If the door is mostly closed, the fire gets choked out and results in excessive smoke, but if its open, will it still heat up well? (noting, I have not burned a fire longer than 20 mins yet and its mostly been small-medium newspaper fires to get any mositure out). The inside is 40" diameter floor surface, and a 17" across dome opening.
Thanks--I am sure I will have more questions as the adventure begins
