What Wood Do You Use?
  • man7sell
    • 88
    #16
    Re: What Wood Do You Use?
    [QUOTE=Capt;139185]I use 2-3 year seasoned Oak, Ash, Maple, cherry and pear.
    We could all wish for such a stack of wood.
    Capt. Paul
    Granite Falls WA, USA.
    Oven In Granite Falls
    • buckeyebreadman
      • Mar 2011
      • 156
      #17
      For southern Ohio, Oak is quite readily available.....I also have some cherry, Ash, Walnut (though it burns hot and fast) among other hardwoods.......NO PINE however!
      • firecapt
        • Jul 2012
        • 13
        #18
        New to the WFO arena, but I've been using almond. I use it ito heat the house in our fireplace also, burns really hot and clean with very little ash.
        m
        • trapper
          • Aug 2010
          • 38
          #19
          I use 100% maple. Actually I am in the midst of cutting and splitting about 30 cords of it at my cabin where I also use maple to boil maple syrup, heat a cedar wood fired hot tub, heat a suana and heat the cabin when i go there in the winter.
          I had a logging truck drop off a load of logs 5 meters or16' long. I used to use cedar as kindling to get the fire going. Now I use a propane tiger torch faster and easier.
          Live life like you're dying....without going bankrupt
          • jeeppiper
            • Mar 2011
            • 321
            #20
            My favorite is Cherry. It is expensive, but it smells soooooo good when you burn it. I also have some Hickory and Locust. Any good hardwood will burn just fine. Once you get the oven fire going, the combustion of the wood is nearly 100% so there is little smoke that is produced. So dont expect much smokey flavor in your foods.
            • deejayoh
              • Jul 2010
              • 1893
              #21
              I burn just about anything to get the fire started. scrap lumber, twigs. But once the fire is going I like cherry. Apparently they are chopping down a lot of the old orchards and replacing with dwarf trees - so there is a lot of it around
              Man7sell - Curious if you've used any fir? pretty common around here (I'm in WA too) but not sure how it is with popping/spitting
