I got a load of Doug Fir (DF) the other day and separated it into 15 lb stacks.
My wife wanted to bake today so last night I took 3 loads (45lbs) to pre-heat the oven.
I have a home built 43in Pompeii. 5 1/2in thick walls with cladding and 2 1/2 in floating hearth.
It was a normal, slow build-up and chimney was at 400+ and I started adding more wood.
DF burns hotter than oak I think, and quicker, so you have to put wood in slower or you waste fuel.
It took about 45 min to get 1K all around and I held it for 1 more hour. Pulled the coals and sealed the oven at about 7pm. At 11pm the oven had pulled back to 500, and today at 6am it was 380 floor and 420 roof.
At 7am I started another rapid burn with 3 batches of DF.
It was at 1K in 20 min with the DF (cut into 2x2x18 strips). I held this for about 1 3/4 hours until all of the last batch of wood was used up. Did not take out the coal and just sealed it up. Door temp was 820 at 9am.
It is now 9:45am and I am going to check it at 10am for temp and I will update this thread at that time. ML
