Oven temp issues - quest for holy grail
  • pizzafun
    • Jun 2011
    • 28
    Hello,
    STruggling with my Andiamo 70.
    My first couple experiences were that the top of the pizza was cooking but the bottom was not.
    My next experience was that I put a pizza in the oven & it it immediately caught fire on the bottom.
    I do have an infrared temp gun & I am looking for 850 degrees.
    I let the oven cool for about 45 minutes after I burned the pizza with no door on & the bottom was undercooked & the top of the crust was not cooked enough.
    I use a log holder & good wood.
    suggestions? or am I far away from getting there?
    thank you.
    Re: Oven temp issues - quest for holy grail
    Try casting about half a teaspoon of semolina onto the floor prior to placing the first pizza. It should turn black in 3 secs. 2 secs= too hot, 4 secs= not hot enough. I always cook my first pizza with about a third of it in the entry, because the oven floor is way cooler there. Subsequent pizzas can be placed a little further in.
    • pizzafun
      • Jun 2011
      • 28
      forgot to mention that I do not use the door in the front at all, i did not use a burning log but rather very hot coals from the wood that burned, I do not move the coals back & forth while alternating the places I put the pizza (maybe I should), I have the coals sit in the back & side
        Maintain a flame, with your fire on the side, that extends to the top of the dome. This will cook the top of the pizza better and give you an oven light.
        • pizzafun
          • Jun 2011
          • 28
          thanks for your help! I will try the flour test. Should I move my coals from the left to the right for each pizza? Is 800-850 the target temperature? I assume I can add wood during the process if I am cooking 9-12 pizzas? any other tips?
            I usually don't move the fire at all. If cooking lots of pizzas I just fire up for longer, like 3 hrs. If only doing about 5 pizzas then 1.5 hrs is usually sufficient. But every oven is different. Keep firing and cooking. If you cast a vermicrete insulating slab it may not be properly dry yet and that may be a contributing factor to the floor cooling off fast.
