i'm planning to fire the oven up tomorrow to cook the sunday roast and maybe a few loaves of bread, i'm just wondering the best way to do it!
i'm thinking of firing up in the morning until the dome clears then raking out the ashes letting it cool down for a while then put the door on and see what temperature i'm at! is this the best way to go in peoples opinion?
in my wfo cookbook it says start fire until required temp is reached then push to the back and cook with the door on. my concerns with this are one, i've heard about backdraft fires when you seal in a live fire and also wont the door being on just put the fire out therefore causing too much smoke and ruin the food? and two, if i only fire for say 45 mins to an hour to get to the required temp say 190 - 200 degrees the dome wont be hot enough clear and will be black with soot does this matter?
thanks for any help
keith
thanks for any help
keith
