Re: Oven Fuel Consumption
That is the same interesting point that snyderadam has raised. This has been actually puzzling me and I used to express it this way:
What guarantees the equation Q = c m dt to be valid so long as c changes as the temperature rises?
Thanks david for your careful notice. I hope somebody can find the answer.
Originally posted by david s
View Post
. But I DID find numbers the best way to express the world, even if the world turns out to be a bit different. Moreover. It was from here where I decided that my experimental steel oven should perform as I wanted my oven to perform, ant that is how it was built.
