Re: Temperature ratings in wood-fired ovens
After you have fired your oven many times you won't rely so much on temp gauges, because it will do the same thing. Most take 1.5 Hrs for heat to soak the bricks and around 1Hr for the inside to go white. For bread or roasts a cheap oven thermometer that goes inside the oven is quite accurate and measures the temp where you want it.
