High Heat Loss
  • #61
    Re: High Heat Loss
    The higher the temp; the greater the heat loss. The curve is expotential
    • #62
      Re: High Heat Loss
      I could clearly see both sides of the argument here.
      A well insulated floor may not need as much thermal mass to retain heat. An uninsulated floor requires more thermal mass to retain an equal amount of heat. Now, if the uninsulated floor was sitting on a slab with cooling fins underneath with constantly circulating air, heat loss will be tremendous.
      George
      George
      My 34" WFO build
      • #63
        Re: High Heat Loss
        The longer your fire - the more stored heat you have to lose....
        My 2nd Build:
        Is here
