hello. I was going by the pompeii oven plans on forno bravo. it says to cure your oven with increasingly larger fires. First fire it says to get up to 300 degrees for at least 6 hoiurs. Was just wondering where you measure the temperature with infrared thermometer . On fire, top of dome, floor.? I am getting 3 very different readings. thanks for your imput, Russ
