Ciao everyone, hope you can help. I have a brick pizza oven we built from scratch in Chicago IL. We used refractory cement and fire brick on top for the floor, and then firebrick, refractory cement and insulation for the walls/dome. Then have Chicago common brick on the exterior/face of the oven for looks (to blend with outdoor kitchen). The dome walls sit on the firebrick floor.
I am finding that I am unable to get optimum temps unfortunately. I'm no expert, but I believe it's in part due to Chicago rain/snow creating moisture that soaks into the brick and inhibiting the oven from heating efficiently. I need to get a good cover or something I suspect, to try and minimize water intrusion. Brick is like a sponge as I'm sure you know, especially Chicago common brick. I am also going to try to find a way to seal the brick better with a masonry product - try to keep water out, which again I suspect is contributing to my cooler oven?
Next, I don't believe the floor was insulated properly by my mason. Too late now, so I'm wondering if it makes sense to invest in a refractory floor by Forno Bravo, or if there's another solution? I just can't seem to get the floor hot enough to cook the crusts well, and perhaps the oven temp overall suffers because heat is lost thru the floor? Not sure, I'm just throwing out theories here.
I've spent so much money & time on this thing, with nothing but frustrating and disappointing result. I really hope I can narrow down the issues & figure this out. At this point, with my limited knowledge, I suspect moisture and a less than ideal floor are 2 of my problems, but could also be that the chimney isn't in the right place. I've dreamt of having this for years and it's been a pretty big failure thus far, so any help would be appreciated!
