Hi,
In the FB (and other) descriptions/instructions it is often referred to the thermal mass of your oven. This mass is crucial for the heat-up time and the baking time (together with a good insulation to reduce heat loss). Practising your oven will of course give you the best procedures and "rules" for these times and the oven temperature.
For planning purposes the more scientific approach would also be intersting (and possibly helpful?). I know how many bricks (and their mass) my oven dome and floor will consist of and I know (approximately) how much dry mortar I will use. If I knew the specific heats of theses materials (from say 15 C which is the lowest useful for cooking and up to 600 C which is the practical maximum) I would be able to estimate the thermal mass of different design (using more bricks or more mortar). Applying and estimate for heat loss (experience) would also give me an estimate of heat-up and cool-down times. Can someone out there help with the specific heat data?
regards from Karl
regards from Karl
