Re: Driving heat across the cooking floor
If I'm setting the dome on the floor, wouldn't there be no cutting of the floor, except at the entrance? In what way is it harder to cut? I've never cut any firebrick, so I guess I have no frame of reference. Finally, how much more expensive? I'll take your word for it that it's not worth it, but in my quest to learn more about this subject, I now must know these answers!
Won't that catch on fire after a few uses? Sounds like a pretty expensive way of building a fire. :-)Originally posted by Frances View PostThanks Jim... that's just the kind of advice I think I can follow. I will add one piece of old squared wood to my Pizza baking equipment.
No. It's not worth the expense and difficulty of cutting. At pizza temperatures low duty is the way to go. Now if you were building a blast furnace...
If you have the high duty or can get them cheap, there is no problem with using them, but they are not worth searching out.
Does having a higher-duty brick in the floor make/keep it hotter? I know the insulation must be there, but will this make a difference if great pizza crust is my main goal?
Frances, I just use a piece of old squared wood (actually a home made oar) to push the coals from one side to the other.....a poker for the logs (if any)...then some dry wood to refire. But if you're in the raging stage I'm not sure it's as easy to move....Originally posted by Frances View PostHow do you push the fire to the side and what tools do you use?
I've tried, but when faced with a raging fire nearly taking my eyebrows off, trusty garden rake in hand, and a hungry rabble behind me, I usually take the easiest path, which is shove the stuff to the back and get on with it.
For a minitue there I thought old George was agona whack me with his rake and peel. Glad to be of service.
The fruit preserves must have been OK if I am the "King". Did you share with the crumb grabbers or hoard it for yourself ?
I think I might change my name to stalled in Olympia ( no building progress yet, just materials )
Back on topic
Heat moves from hottest to coldest. It's like air moving into a low pressure area. The heat will always flow to the coolest spot until temperatures are equalized. Having said that, I am a right side guy ( I think)
Bruce
As for knowing when the pizza is ready for turning... thats exactly the time it takes to put the big peel down after inserting the pizza and geting into position with the small round turning peel.
Dutch's got it. When the fire's in back, you can't see the back of the pizza as well as when the fire's on the sides.
I was a right side fire guy until Bruce, the Broken Cookie and Fruit Preserves King saw me hit the wall a couple of times with my peel while I was turning pizzas (the wall is on the left). He says offhandedly, "Hmmm - maybe you should build your fire on the other side, then you wouldn't hit your handle on the wall". Simple solution to a very minor problem that I didn't even recognize. Now I'm a left-hand guy. I ignored the fact that I'd let habit completely overshadow reason and/or thinking. Thanks again Bruce!Last edited by gjbingham; 05-27-2008, 10:47 PM.
That would be the logic...I think...but an added reason to fire on the side as opposed to back is that you will see the color on the crust and thus know when to turn...Originally posted by jwnorris View PostIs this because with the fire in the back the natural tendency is for the heat to drive to the opposite side of the done and that is where the vent is? Therefore when the fire is at the side the heat will drive completely across the dome before seeking the vent.
Is this the correct logic?
J W
All the best!
Dutch
Let's have an argument about fire left and fire right. I'm a fire right kind of guy.
Is this because with the fire in the back the natural tendency is for the heat to drive to the opposite side of the done and that is where the vent is? Therefore when the fire is at the side the heat will drive completely across the dome before seeking the vent.Originally posted by james View Post<snip> I also think the fire is much better on one side (the left of me), rather than the back (over even on two sides). James
J W
Hey! I have cured sick children, doesn't that count?
Not to worry Robert. I give bad advice all the time!
That's the incredible resource of this forum. You would never just take one person's word for an answer. You search the forum and read all that you can find on the topic. Most opinions agree, some don't. We base our decisions on what seems logical for our individual situations.
Having completed your build, I'd take your word as almost gospel for building issues. Conversely, I'd totally ignore you about curing issues until you've suffered the first crack, then second guessed everything you've done to this point. Reality sets in, huh? Look forward to your cure bud! Enjoy the process. Ignore the minor setbacks.
George
Since I am getting ready for curing and cooking of the pizza, I decided to re-read the entire thread. I don't know if anyone else does this, but at each stage of my build process, I tabbed key threads that I would find absolutely beneficial to me. Now I am at this juncture and am pleased with the next stage "Plasma"! Of course plasma will not be day one
This was one of my earlier stages of comments and input that I wish I could revise some things. Silly when one goes to the early days of input. I hoped I still helped back then.
