portland cement to vermiculite
  • portland cement to vermiculite
    whats the mix ration porland cement to vermiculite for the below floor isalation layer.
    Re: portland cement to vermiculite
    complete instructions:
    Pompeii Oven | Brick Oven Hearth
      Some have used ratios as rich as 5 to 1 and many of us have used 9-10 to 1. I used 9+ to 1 using the slurry method (cvduke's method) and had no problems using that lean a mix. Do a search with "cvduke" in the search box and you should get his thread on the method.
      The leaner the mix the better the insulation value for a given thickness.
      Hope that helps,
      Wiley
