Advice for mounting a Casa2G100..
  • Fiamma Bella
    • Mar 2023
    • 1
    advice for mounting a Casa2G100. A picture of original during demo. Thank you.
    Hi Flamma Bella,
    Welcome to the forum. If you haven't seen it here is a link from Forno Bravo (Mobile Pizza Oven Trailers). At the bottom is Have any questions?. I'm also starting a new topic with your post. Hopefully someone on the forum with experience will chime in
      • 9213
      As the oven is a Forno Bravo product you should address your question to them.
      Regarding the trailer you should make sure it is fitted with shocks because the bumps and vibrations from road travel are very destructive for heavy brittle materials. The springs on the trailer should also be matched to the total load.
      A single axle can be dangerous, a double axle is far better. The heavier the oven as well as the higher the centre of gravity, the greater the problem.
