I'm just in the process of curing my 36" pompeii oven and have been getting a lot of smoke coming out the front of the oven as opposed to going up the chimney, the chimney opening in the oven has been built according to the plans and has an 8" by 4" brick chimney as shown in the photo from the plans.
i'm not sure is it because i'm only lighting small fires now so obviously its not very hot or is it something to do with my chimney opening design. i'm planning on adding a couple more courses of bricks to the top of the chimney to see if that helps. i live by the coast so there's a lot of wind. Any help would be welcomed.
thanks
thanks
