Re: Oven Door? Insulated or not. Pros & Cons
Stan,
I think you are correct, the door is the weak link. But if the oven meets your needs, so what. Also the smaller the oven, the larger the door opening, relative to the the ovens size, which exacerbates the heat loss through the door. A small oven will have a fairly wide door while a huge oven door looks more square.
Stan,
