I picked up masonry cement to be used for my stucco mix at Home Depot b/c I saw a sign that read "use masonry cement for stucco" there. After getting home, everything that I have read says to use a mix of portland cement, hydrated lime and sand--the mix varies based on the different layers, but portland cement is always a constant.
The two things that I like about the masonry cement is that 1) I have it and 2) it is lighter in color so will likely take the added cement color better. I have NO experience with stucco, so will using masonry cement give me as much strength and durability as portland cement?
Thanks for all suggestions!!
Claire
Claire
