I am planning on building my vent/oven landing area about 1/4 inch away from my inner arch as a heat break. I plan on shoving some insulation board between the two to top it off. I wonder though, if it will be a fatal move, meaning that later I may wish that they were connected for strength. Can anyone comment on the wisdom or folly in not connecting the two?
Tom
Tom
I don't see the advantage. You would still need to cut the transition bricks to conform the vent to the dome. (even though they won't be touching)Then you would need to add butress bricks to reinforce the sides of the vent to hold the weight of the chimney (or to keep it from shifting to the side and falling down)! I could be wrong but it seems to me like a case of 'If it ain't broke, don't fix it!
