I want to build a WFO on the cheap. I am completely new to oven building, so maybe my ideas are dumb... but since this oven is for cooking and not for looking, I think I might be able to get away with some major corner cuts.
My first idea:
I have a sheet of 1/4" steel sheet metal big enough for the roof, which I would cover with regular red bricks to add thermal mass.
For walls, I could build the on or near the ground, and use rocks and dirt for the side walls (not much clay in the ground here).
For the floor, I'm thinking some kind of an insulating layer, (as not to conduct too much heat away from the bottom), topped with a layer or two of regular red bricks, topped with a couple layers of unglazed quarry tiles.
I'm not sure what to do about an opening yet, maybe a sheet of steel cut to size and shape.
OR!
Has anyone tried using a sawzall to add a chimney, add some bricks, and convert a regular old electric oven into an outdoor WFO? These things are available everywhere for free. The only problems I can think of would be size constraints. Your thoughts??
My first idea:
OR!
