So I am about to finish up my dome and so I am trying to think ahead a little bit. So, I have decided that I am going to build a brick chimney (mostly due to cost but also because I think that I am going to have left over brick) but I have the following questions:
1. If I decide to cast a base for the first coarse to sit on (I think I will need to because of my arch), is there a special mix that I will need to do the concrete out of?
2. Is there a minimum height that I should build my chimney that will improve my draw?
3. Is there any recommendations on chimney cap manufactures/designs for this type of chimney?
4. Are there any special considerations that I need to make where my roofing materials butt up against the chimney since this system is not a double walled system?
5. Any other tips or recommendations?
Thanks!
Thanks!
