Polished concrete tables.
  • Mike D
    • Oct 2010
    • 342
    #31
    Re: Polished concrete tables.
    splatgirl-
    This will be more than a 2 bag project. I was just saying 2 bags because that is what fits in a mixer and how I would be adding the color. You can see my build if you want.
    http://www.fornobravo.com/forum/8/ro...-14700-20.html
    - I plan on cast in place for around the oven and a mold for the prep area next to it. I would get them both ready to pour at the same time (one after the other to use the mixer effectively).
    Mike
    • Mike D
      • Oct 2010
      • 342
      #32
      Nic- (or anyone else)
      Is counter-flow a dry powder or a liquid. I looked it up at Fishstone, is that the stuff?
      Mike
      • splatgirl
        • Jun 2009
        • 473
        #33
        Powder. At least the jar I've had around for a few years.
        Products: Counter-Flo - Fritz-Pak Concrete Additives, Dallas, Texas
        • Nic The Landscaper
          • Jul 2010
          • 100
          #34
          It's a powder, and you found the right stuff at fishstone
          • Mike D
            • Oct 2010
            • 342
            #35
            Thanks for the help Nic and splatgirl.
            Mike
            • Mike D
              • Oct 2010
              • 342
              #36
              So I got my supplies, and I was going to try and pour a couple of test pieces for the color. I don't have any reference of where to start from.
              -How much Iron Oxide would you typicaly use per bag (roughly)?
              I was going to do 2 one bag tests to get an idea what the coloring would do. I will use a wheelbarrow to see how easy it is (if it works that way).
              Mike
              • Tscarborough
                • Oct 2009
                • 3341
                #37
                As a rule, most iron oxides will use 2-2-1/2 # per bag of portland per yard. It can vary widely though, so you have to test it.
                • Mike D
                  • Oct 2010
                  • 342
                  #38
                  I was planning on using sakcrete 5000 bags (80lb).
                  Following Nic's
                  2 80lb sacs of Sakcrete 5000+
                  8 oz counterflow
                  12 to 14 quarts warm water
                  dry color to taste, always use iron oxide based colors not carbon based.
                  And the Cheng style of method.
                  Mike
                  • GianniFocaccia
                    • Jun 2009
                    • 1645
                    #39
                    Mike,
                    Sorry - I haven't kept up on this thread, but have you heard of the Quikcrete Countertop Mix?
                    John
                    • Tscarborough
                      • Oct 2009
                      • 3341
                      #40
                      42x80# sack=1 cuyd, so your range will be 10/42=.23# per sack to 12.5/42=29# per sack of color.
                      • Mike D
                        • Oct 2010
                        • 342
                        #41
                        -GianniFocaccia- I have seen that stuff, but what I have read is the sakcrete has a better aggregate. So that is what I'm going with (as well as I have all the stuff already).
                        Tscarborough- Thanks that is what I wanted, some sort of barometer to make a couple of test pieces. If I make mix one bag with .25# (1/4#)of Iron Oxide and another with .125# (1/8th#), should that give me an idea what the range of gray would be like?
                        Thanks for the help guys
                        Mike
                        • Tscarborough
                          • Oct 2009
                          • 3341
                          #42
                          That will give you a range. The general rule is no more than 10% color by weight of the cement in the mix, so to break that into 80# bags, it is 6x94#=564 of cement per yard/42=13.42# of cement per sack, so no more than 1.34# of color per sack, so your real range is 0-1.34# per sack.
                          • Mike D
                            • Oct 2010
                            • 342
                            #43
                            So maybe more like do one with .25# and another with .75#. I don't think I want it really dark. How does that sound?
                            Mike
                            • Mike D
                              • Oct 2010
                              • 342
                              #44
                              I did a test piece, came out ok. I think I will use a vibrator when I do the pour around the oven. Does any one have a good slurry mix? I am trying to test this process out as far as it will go.
                              Mike
                              • Tscarborough
                                • Oct 2009
                                • 3341
                                #45
                                An orbital sander makes a good form vibrator. By slurry are talking about a slurry to coat the forms?
