I just finished the dome on my 42" oven. I'm wondering if I should start curing the oven before I build the vent and before I cover the dome with the fiberglass blanket?
Also, I have some minor spaces between bricks in the upper part of the dome. Should I try and fill them in with castable cement? I have covered the entire dome with the refractory mortar and I will be covering the dome with 3" of fiberglass blanket. I will be enclosing the entire dome and covering it with insulation as well.
Thanks for the help!
