> hi everybody,
> since i just finished the dome this last saturday, i myself too, feel
> that i am done building my breadoven and are now able to start
> cooking......
Yay!!!
> i have another question however, concerning the vent and chimney?
> can i get the steel vent and flue at home depot or do i have to get it
> custom made? i know some of you just did it yourselfs, cutting steel
> and welding it together. it looks easy enough, but i don't know how to
> welt yet. (learning to weld is a project for some other time).
Yep. Home Depot carries stove pipe & chimney toppers that will work.
Get a 3' or longer pipe section (the stainless steel double-walled one
will last years & years) and a chimney top that fits on top. The
chimney top will provide a spark arrestor function.
> would a chimney of 2 feet lenght be enough or would 3 feet be better? i
3 is better as it will draw more. In fact if you can get it a foot
taller than the roof will be (within 2 feet) that's best. (The "within
2 feet means you measure out 2' from the chimney location and mark the
highest part of the roof you hit. Make the chimney at least 1' taller
than that -- it helps provide room for the draft to exit the chimney.
So in the case of mine where I've got a steeply pitched A-frame roof,
it really only had to just come out the roofing but it actually sticks
up about 10".)
> am intending on using a 8inch steel round chimney.
> also, can i use the same portland/fireclay/sand mix to cement the steel
> vent & chimney in?
Good size. I've got a 9x12 rectangular one that draws like a champ.
Any smaller than 8" may not draw quite as well so you'd want to have
more of a baffle in front of it to force the smoke up the chimney
(which will lower the front door).
> has anyone some piece of advise? what i should avoid?
Avoid the plain galvanized pipe sections. They'll outgas some nasty
stuff because this will get *hot*. They will also corrode over time
with the effect of the acidic smoke & burning galvanization...probably
only last a couple/three years. The single-wall black chimney pipe is
better (next best to clay flue liners & stainless steel double-wall).
> any advise is very much appreciated!
> thanks to all of you to get me so far
> simone
> cooking......
Yay!!!
up about 10".)
> vent & chimney in?
> simone
