First, I was wondering if there is a procedure for attaching a terracotta chimney to the vent (top of the transition part). Is high temp mortar used to attach the flue? Build up an area with bricks?
Second, I would like to put stucco around the flue (like an "australian" style oven). Do the flue and the transition/vent get insulation blanket around them? It seems like this would be an extraordinarily hot area and I would think that expansion/contraction during cold seasons would crack the terracotta without insulation. I feel like the flue should be insulated somehow or is the air space generated from the chicken wire enough...
Thanks in advance,
Sarah
Thanks in advance,
Sarah
