Hi Guys/girls
I'm in the final stages of my oven build and need a little help.
I want to render/stucco my dome but not sure on the best way to do it. I have blanketed the dome, chicken wired around the blanket and then added 3-4" on vermiculite (mixed with cement) over the blanket and wire. I was going to render/stucco over the vermiculite but having done a little research on this site I see a lot of people putting down a layer of chicken wire to hold the render/stucco together and reinforce it. This is where I get a little confused as some say they do it in 2-3 layers so do you use chicken wire 2-3 times?
I have also read that some use reinforcing fibers in the mix but so far no luck in tracking a supplier of this stuff. they know about the product just don't know who sells it, frustrating.
Any advise will be greatly appreciated.
Almost forgot do you wet/hose down the vermiculite before putting the render on to reduce the vermiculite sucking out all the moisture out of the render. If so do you give the oven a quick spray with the hose or a decent spray.
Oscar
Oscar
