Hi guys,
I am considering if and where I should place my chimney. I have drawn two diagrams to illustrate.
I'm building a simple clay oven and some of these are without chimney and just vent through the door. But I would prefer to have a chimney and already have a nice piece of stainless steel for that purpose.
Now, I have just build a solid stone door arch (no dome yet)
I wanted to keep the construction simple because building the chimney opening inside the door arch seemed to complicated for me.
The door arch is 27cm high (10.5") and I was planning to make that 63% of the dome height. (as I said ,the dome has not been build yet)
I would like to place the chimney directly behind the door arch but that raises the following question:
Do I
A: Leaf the opening of the pipe horizontal and place it on the recommended 63%?
The problem with this is that it would leave a small on top of the dome where smoke would gather, would it find it's way out the chimney?
Or:
B: Cut the chimney pipe to follow the shape of the dome but thereby having the back of the stove pipe opening be higher than 63%
(see diagramgs)
The (planned) measurement of the oven are:
Door opening 47cm x 27cm (18.5" x 10.5")
(this has already been build)
Dome: 80cm x 43cm high (31.5" x 17" high)
Chimney diameter: 15cm( 6")
Cheers,
Matt
Do I
Or:
(see diagramgs)
Cheers,
Matt
