Just installed a 47" Modular oven in a trailer. The Door opening is 22"x 13" to the top of the arch. If I do the math its 286 square inch opening minus whatever the arch takes up. I used a 36" tall 6" insulated chimney. From what I gather the chimney should be about 10-15% of the opening 6" chimney is 28.27 square inches.
With all that said I am having issues with the Draft. I have a good deal of smoke coming out of the front. Mind you I am burning a small fire at the moment, still curing right now. I also do not have a rain cap on so I'm not sure if the wind is causing issues. Any ideas if when the oven runs hotter the heat will help increase the draft or if I should add another foot of chimney on??
