I'll be moving to a new place soon which means building a new oven. It's sad to leave the current cob/brick oven I have, but I did screw up a part of the front, among other things. Lessons learned. I had built the oven to be taller than normal because I wanted to also be able to throw roasts or dutch ovens in there. I am reminded of some of the stuff I've read on here about Greek-style ovens. But there are some good rules of thumb I tried to generally follow even when I was abandoning the recommended height for pizza or bread. However, I wondered how the rules of thumb change for nonstandard heights.
I'm thinking my next oven may be 42" diameter at the smallest inside, and we might go all the way to 56". I try to get something upwards of like a 14" front to slide the larger of my dutch ovens in and out. It occurred to me if I increased my diameter that I might just get away with making a more normal pizza oven anyways What are the recommended proportions of door height to oven height again?
I don't think I ever asked but I wondered what are the proper ratios for chimney height to oven height/diameter/whatever. Generally I was worried about the chimney. I wasn't so sure where I should have placed it and kind of just improvised its size. I was also curious about how far forward the front should extend from the dome, factoring in nonstandard heights. I would figure a long front would do some to offset this.
It might be worth another thread, but I'm curious how I might design the door into things up front. It was too much of an afterthought here, but I'd rather make it built-in or otherwise robust so I can easily do indirect cooking/smoking overnight or bake bread during the day.
