First of all, it is a high of 81 degrees in Phoenix today. Not sure if I should brag or complain!
I installed a vent that starts out 12.5 x 4.5 inches wide at the bottom, then going to 9.5 x 4.5 at the transition to the flue. The flue is 12x 8 interior, and then transitions to a smaller and smaller diameter- ending up in a 4 inch diameter vent 42" tall in total (trying to get the smoke up and out).
About 50% of the smoke is still coming out of the front (instead of up the flue). I see the potential problems as:
1. Going from a 9.5x4.5 opening vent to a 12x8 flue creates a high pressure (Bernoulli's law), no chance for it to suck up/out through vent
2. Ending vent of 4 diameter is too small
3. 42" tall stack is too high
4. My entire accomodation for the vent is one brick length (wanted a very shallow transition for easy access), and that is too shallow
5. My exit is 1" higher than the exit from the oven, and it makes it too easy for smoke to exit there.
Pictures attached (I put the wood form infront to force the smoke out when taking this pic). One one is correct? How do I fix??
