I had originally envisioned finishing my oven with an enclosure, but now, in part for aesthetic reasons and partly for space and view-preservation reasons, I'm thinking of doing an igloo style as well. So I'm trying to figure out how to go about stucco.
My biggest puzzle is how to deal with the fact that the insulated dome is pretty lumpy. In particular I added an extra inch of blanket on the top because I had a scrap that was the right size and that seemed like the place that needed the most insulation. Can I fix this with stucco, by just adding more render to the low spots and less to the high spots?
I know one way of fixing lumps is to have a layer of vermicrete, but a) I don't feel like I need the insulation with 4-5" of blanket in most places, b) vermicrete sounds like a pain and most importantly c) I don't think I have enough room between the oven and my deck to apply vermicrete and stucco. How thin can you do vermicrete?
Related question: I tied down my blanket with rebar wire. If I were to add a bunch more rebar wire, would that be a substitute for chicken wire as a base for the render? Or rather, since I'm pretty sure that in theory the answer to that is yes, would the amount of wire required be insane and way too much work?
-Ryan
-Ryan
