Hi
I want to put a chimney on my outer arch. I don't want to have an exposed SS flue so am planning to "cover" it somehow.
One idea I have is to enclose it within an outer chimney of, say, vermicrete.
My question is, can I just shape the vermicrete around the SS flue or will that cause the steel to corrode?
If ghe concrete will cause corrosion Is there some way of spacing the concrete off the flue?
Is home brew a better idea than vermicrete?
Cheers
Max
Cheers
Max
