Need some help. I have covered my oven in metal lather in preparation for stucco. I have carried the insulation to cover the chimney area but I am at a los whether to secure with metal lathe or concrete board/hardibacker. The metal lathe is exactly easy to work worth to create smooth crisp lines around my chimney area. Where should I proceed from here? I have ttached some pictures so everyone can visualize what I'm talking about.
Stainless Steel Front Entry
Re: Stainless Steel Front Entry
I can't see any insulation in your pics. You can secure the blanket's form with some mesh. Most folk then give it a layer of vermicrete to even out all the lumps and bumps, then do a layer of stucco. Or are you intending to build a dog kennel over the thing? Either way you may as well cover the entry in blanket too.Last edited by david s; 09-15-2013, 02:03 PM.Kindled with zeal and fired with passion.
David,
Thanks for the reply. I wanted to show pictures of the metal (dog house) that was supplied by FB for the build before I attached the metal lathe. I went ahead & attached the lathe over the insulation and around the chimney area.
Originally posted by kkgator View PostI wanted to show pictures of the metal (dog house) that was supplied by FB for the build before I attached the metal lathe.
Supplied from Forno Bravo?
It looks like the first year apprentice made it as a homework project.......
