I am about to start construction on a masonry chimney but have some questions about my design:
I have two 8-inch diameter, 12-inch tall flue liners. I was planning on mortaring them together to make a 24-inch tall chimney but am not sure whether I need that height. I am considering using just one of them. Are there any considerations besides zoning restrictions that would make having a shorter chimney a bad idea?
I am going to build a brick chimney tower around the flue liner with regular clay brick and an air gap between the flue liner and the tower. Will the heat from the flue liner be too much for the non-firebrick tower or should I use firebrick to make the tower?
I am also going to fabricate a steel buttress frame for the brick tower to distribute the weight so it is not all centered on the arch. Are there any considerations about such a strategy?
Thanks - C
Thanks - C
