I just closed the dome on my Pompeii oven and it is time to get serious about fabricating a vent. I plan to have a stainless steel vent fabricated and have a few questions.
1. What type stainless should be used? Is 304 ok?
2. What thickness should I use?
3. What angle should I use for the funnel part? I was thinking 45 degrees.
4. What is the best way to fasten to the brick walls and is there some type of caulk that can be used to seal the gaps?
5. Should I wrap the whole thing in insulation after installation? I plan on enclosing the oven when I'm done.
Any suggestions would be greatly appreciated.
