I'm seeing both smooth and rough domes out there, Does it matter?
Do we want a smooth dome specifically for pizza?
We tend to build nice smooth good looking domes now...but why? Does a rough dome do any harm? Granite, the ones I've seen are rock based domes.
It might even work better for a bake oven, maybe causing turbulence to keep the heat in???
I guess the point might be that if you're using firebrick, you will have a relatively smooth dome surface and shoud not be too worried about it being perfect! ....don't let some roughness worry you too much.
food for thought....here's are "flat" stone and rough stone dome examples
It might even work better for a bake oven, maybe causing turbulence to keep the heat in???I guess the point might be that if you're using firebrick, you will have a relatively smooth dome surface and shoud not be too worried about it being perfect! ....don't let some roughness worry you too much.
...enjoy every sandwich!
